PM7 ecu grounding issue
Old Nov 4, 2022 | 10:21 AM
wlt911's Avatar
Icon7 PM7 ecu grounding issue
My PM7 ecu on my 88 CRX appears to have a grounding issue. I have lost tach, fuel level, temperature, directional signals, and AC compressor function (fans come on but compressor never engages) - pretty much everything that depends on the ecu for their grounds. The engine actually runs very well. I don't know if the IAC valve is even working.
I'm hoping first of all that someone can give me a pinout on the ecu (OBD0/PM7). Also if anyone with any info on this issue could respond it would be greatly appreciated. I have also tried three different ecu's with same results.
Old Nov 4, 2022 | 02:38 PM
jlicrx's Avatar
Default Re: PM7 ecu grounding issue
PM7 pinout is the same as the PM6
Are your ground wires at the thermostat housing connected, clean and secure?
Old Nov 4, 2022 | 03:09 PM
wlt911's Avatar
I know that now. I just discovered three fuses that blew around the same time. That led me to believe it was something in common so the ecu came to mind. I have just resolved the issues. Thanks for responding.
chrisfromsrq
Aug 11, 2009 11:07 AM
crxaddikt
Jul 9, 2007 05:17 PM
crxaddikt
Jun 10, 2004 07:28 AM
