Need Help or Sugestions
Old Nov 4, 2022 | 09:35 AM
justadummy's Avatar
Default Need Help or Sugestions
I’ve recently changed my head gasket on my D16Y8 engine. After reconnecting all of my vacuum lines and cleaning my throttle intake, I have a high idle. Once started it goes to a fast idle with or without my throttle cable connected. Not sure if this is a sign of a warped head or a bigger problem. Any advice would be greatly appreciated
Old Nov 6, 2022 | 02:07 AM
White_EG1's Avatar
Default Re: Need Help or Sugestions
So when you start the car it’s goes to regular idle then slowly increases to about 2k?
Old Nov 6, 2022 | 07:55 AM
justadummy's Avatar
It will idle and when I manually give it throttle it seems like it gets stuck and continues to rev to its limit, cleaned the throttle intake and everything, not sure what’s going on with it
Old Nov 6, 2022 | 12:05 PM
White_EG1's Avatar
Check the play on the throttle cable and it’s hard to understand what your saying or what’s the exact Issue
Old Nov 6, 2022 | 12:33 PM
justadummy's Avatar
The issue is that it doesn’t retain the idling, and revs up without giving it throttle.
zcole1993
Oct 29, 2012 08:08 PM
7861prada
Apr 8, 2010 02:25 PM
h-o-n-d-a
Aug 3, 2009 05:15 PM
honda06si
Nov 24, 2004 02:35 PM
Cburt24
Feb 20, 2004 02:38 PM
