UPDATE 10/22/23
Je 9:0.1 81.5mm pistons- 150.00 SOLD Go autoworks gt500 fmic-150.00 (garrett core 18x8x3.5, inlet/outlet are 2.5" SOLD SOLD Id1000cc/ bseries (cleaneed and flow tested 2021)-100.00SOLD
Ptp turbo blanket-50
circuit hero shifter extender- 28.00
prosport boost gauge-18.00
96-00 civic airbag equipment-60.00 SOLD P28/s300v2 with capacitors replaced a couple year ago and bbg components installed-100 SOLD SOLD- hondata CPR kit-220 SOLD SOLDTurbonetics tnx-3060 BB turbo w.85ar housing cermaic coated- 300SOLD SOLDturbonetics t3/.65ar cermaic coated vband housing for the tnx-3060 turbo- 50 SOLD SOLD skunk2 proseries intake manifold(b16/Itr flange pattern) with oem iacv, iat, fuel rail, and filter-150SOLD
oem honda obd2 240cc injectors with clips-20 SOLD Aermotive stealth 340 fuel pump-50 (Low pressure relief valve on the 340 pumps. Not suitable for high boost builds)SOLD
oem honda halfshaft-50
oem p73 (type r) pistons on p72 (gsr) rods-100 SOLDNgk b series ignition wires (low mile usage before switching to hondata CPR)-20-SOLD SOLD oem honda spark plug cover-20 SOLD SOLD b series clutch housing SOLD (shafts, gears, and forks being scrapped)
aem uego wideband kit-80 ( cable sleeve broken. No wires torn, ripped, or showing), with extra sensor and cable
b16/ls oil pan- 80
B16 windage tray- 40
B16 oil pickup- 40
Discontinued b16 timing cover heat shield-50
b16 upper timing cover- 40
b16 lower timing cover-40
b16 timing belt(500miles used)-50
ARP b16 headstuds(used)- 50
Bseries crank pulley-50 SOLD 00 em1 p2t ecu-50 SOLD
B20z2 block-60(no cracks in sleeve. Will need rehoned)
ITR crankshaft-300
b series plastic body one piece vehicle speed sensor
TRQ aftermarket 2017 outback front lower ball joint-20
Prices does not include shipping. Apparently cashapp is the only trusted source nowadays. So thats what i use for transactions.
Note:
P28/s300 will be installed in a different casing. P28 casing is need my link g4x ems
Reason: Sold or added
Interested in the steering wheel but dont see price or info on it. Could I get some better pics and pricing please
PMd.
oem steering wheel is peeled at the top of the rim. ill shipped you everything steering wheel related for 30 bucks plus shipping. Unless you want the rest of the airbag system for a straight 60 bucks? Will load better steering wheel pics tonight
PMd.
