Need help with brake issues
Old Oct 27, 2022 | 05:40 PM
baldersdod's Avatar
Default Need help with brake issues
So I installed a new brake master cylinder on my 1990 civic hatchback (1.5 D15B) and after the install and bleeding, the brakes feel SUPER spongy, and have virtually no stopping power. I did bench bleed the master cylinder before installing it. My brake booster, brake pads, and calipers all less than a year old. Any advice would be appreciated.
Old Oct 28, 2022 | 10:52 AM
Maxcapacity's Avatar
Default Re: Need help with brake issues
Just need to bleed all 4 brakes now. Go in order - LF, RR, RF, LR. Did you measure and compare old vs new master cylinders depth from mounting face to the plunger inside the master cylinder? Sometimes the push rod from brake pedal through brake booster needs to be adjusted to compensate the difference.
Most likely you just have air in the lines still..
pythoner
Suspension & Brakes
Sep 3, 2008 04:01 PM
USDM-EK4*
Apr 4, 2008 07:50 PM
bruvaman
Jul 9, 2002 07:19 PM
veejay
Jul 24, 2001 09:39 AM
