Need help and info swap to manual using 4th gen prelude or other Honda.
Old Oct 27, 2022 | 02:55 PM
Jose omana's Avatar
Default Need help and info swap to manual using 4th gen prelude or other Honda.
Hello I'm Jose form Venezuela.
​​​​​​I Own a 01 accord with F23 engine and have an automatic transmission.
​​​​​​Here is almost imposible to find another same gen Accord with the manual transmission. The one there are are in very good condition and expensive to buy.
I found a used f23 manual gearbox imported from USA. That's it.
My question is can I use the shifter, pedals, flywheel, clutch kit, master cylinder, slave cylinder, cv axel, gearbox mount, shift cables from 4th gen prelude or 5th gen Accord with f22 engine.
Or anyone have try and know the modification I have to do to accomplish the swap using f22 parts.
Thanks!
This is my Accord!
Old Oct 28, 2022 | 08:41 AM
Aradin's Avatar
Premium Member
Default Re: Need help and info swap to manual using 4th gen prelude or other Honda.
The mount and axles will be chassis specific. Otherwise most of the stuff is interchangeable. I am using a 4th gen Prelude clutch pedal/bracket and shifter cables in my 5th gen Accord for example.
Simple_Sauce
May 9, 2008 07:02 AM
jlv55
Nov 21, 2004 11:57 AM
whoa its len 2
Jun 16, 2004 08:56 PM
Blkblurr
Feb 2, 2004 03:29 PM
