Suspension Bushings
Rubber bushings are nice for a street car because they are maintenance free, BUT you must be aware and avoid preloading them when working on the car.
Poly bushings are also nice for a street car but a little harsher than the hardened rubber. They generally are designed to move in their housings, BUT you must occasionally inspect and lubricate them or they will begin to bind and tear themselves or other things up.
You can also use a scissor or floor jack under the LCA (or RTA or whatever) to artificially get the car to "ride height" on that component, and then tighten from there. Without a roll-on lift this is normally what you have to do.
CubbyChowder
Jul 10, 2011 08:16 PM
