Wheel hub bearing question
Old Oct 19, 2022 | 05:12 PM
NeoD16Y8's Avatar
Default Wheel hub bearing question
Hey their. So i have a 1995 honda civic dx sedan. I got a d16y8 on it but no vtec. Maybe the head is from another engine. My question is about the front wheel hub bearing. Is their a size difference between a abs bearing and non abs bearing? Koz i bought a bearing and i asked for non abs so when it comes to installation. The bearing that was on my car has a smaller bearing. But it has no abs sensor. And it has a race or sleeve or something that blocking the lower ball joint. Can remove the sleeve and use my new larger bearing? Thank you!
Old Oct 20, 2022 | 07:48 AM
spAdam's Avatar
Loved
Community Favorite
Default Re: Wheel hub bearing question
There are two different sized bearings, but ABS isn't what defines which goes where. Unless your car has been retrofitted with the larger brakes from an EX/Si, you want the smaller bearing. The parts store should have been able to sort this by your trim level and gotten you the correct part.
ajax68
Honda CR-V & Element
Nov 13, 2016 06:58 AM
DACteg
Jun 9, 2008 07:29 PM
WRTEG
Apr 28, 2005 03:04 PM
alexdog69
Oct 18, 2004 02:43 AM
