3rd generation prelude CEL is blinking please help me read it
Old Oct 16, 2022 | 05:44 PM
mr.BA4singh's Avatar
Default 3rd generation prelude CEL is blinking please help me read it
Hello prelude community it’s me again… unfortunately😂😂
I’ve figured out how to jump the OBD connector to get the CEL to flash the codes. Only problem is I can’t tell which code it is this time. The first long flash is what’s confusing me.
Below I’ve linked the video I posted on youtube with the CEL flashing. Any assistance with this issue is much appreciated!
Old Oct 17, 2022 | 02:15 PM
CarParts.com's Avatar
Default Re: 3rd generation prelude CEL is blinking please help me read it
https://youtu.be/hTZ-aOqklXk
Hello,
Hmmm it looks like one long blink, which is 10, and six short blinks. So, I would say it's a code 16, which is defined as "fuel injector".
Old Oct 17, 2022 | 02:57 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Since there is a longer pause between the first long flash, and then the 6 short flashes; then it is likely multiple codes: DTC Code 1 and Code 6.
DTC Code 1: Heated Oxygen Sensor
DTC Code 6: ECT Sensor
If the shorter flashes were right after the long flash (without much pause) then it would be DTC Code 16.
Old Oct 17, 2022 | 03:12 PM
thanks for the reply👍 so i replaced my o2 sensor and someone told me the first long flash is the ecu checking in. does that sound correct?? or should i order a better o2 sensor. also in the process of fixing the cooling system to correct code 6.
Old Oct 17, 2022 | 03:34 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Yes, I heard some Hondas does a check first.
On some model Hondas, if you don't turn off the ignition switch when checking for trouble codes, it will repeat the same trouble codes.
Does your Prelude repeat the troubles codes if the ignition is not switch off? If it repeats the same long and short pauses without turning off the ignition, then it is likely two codes.
Old Oct 17, 2022 | 04:14 PM
so i’m a little confused to what you mean by ignition off and the repeating codes. when i check for codes i put the ignition in the second position and the codes will flash repeatedly. they also flash repeatedly in the ecu on the passenger side floor while the engine is running. could you please elaborate sorry
Old Oct 17, 2022 | 04:23 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
If the identical flashes repeat (where you left the ignition switch in the second position), then it is likely two codes.
What I meant was to leave the ignition switch in the position where it flashes the codes.
Old Oct 17, 2022 | 04:45 PM
the codes do not flash at all in the “I” position they only flash in the “II” position and in the “III” position with the engine running. whether it’s in the “II” or “III” the codes flash repeatedly so i’m guessing they are two separate codes and not the ecu checking in?
^ the codes flash in the “II” position and “III”
^ my car is missing the ignition cylinder and i only have the ignition switch (circled part) to turn the car on. but you can tell the 4 positions apart pretty easily.
Old Oct 18, 2022 | 08:30 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Short blinks are ones, and long blinks are tens. Codes are stored from smallest to largest in number... in order. The rub is that when you turn the key on, the flashes do NOT necessarily start at the beginning. So, one must watch the cycle repeat itself over and over to see the order of the flashes. Your video shows the single long flash first, and then the six short flashes. However, since you know that codes are in fact stored in chronological order from smallest to largest, you can see what the codes actually are because with long pauses in between, it cannot be the other way.
Old Oct 18, 2022 | 09:07 PM
so 6 short flashes… long pause… 1 long flash
it must be code 6 and code 10 like you said
if i ever get another code i’ll make sure to post a little bit longer video
mr.BA4singh
Oct 16, 2022 05:18 PM
Deano_d
Feb 28, 2010 09:47 PM
HondaTuner12345
Mar 4, 2007 07:45 AM
Burnin_ruberv8
Jul 8, 2006 07:44 PM
92-h23a1
Apr 17, 2003 05:50 AM
