Need help!! No Fuel pump prime and no start but I just replaced few day ago
Old Oct 15, 2022 | 09:23 PM
mujunyu520's Avatar
Default Need help!! No Fuel pump prime and no start but I just replaced few day ago
Got a 1994 Delsol VTEC b16a3, fuel pump only primes half-time, and once it primes car runs perfectly.
I also notice that When my key is on position II the engine light will keep on but once the light is off
the pump prime and engine can start.
I have replaced :
fuel pump
map sensor
fuel filter
fuel injector
However, What I placed may not really point to the issue. Someone told me it may be the ECU was faulty or something.
Got this issue for a week already.
Before that My car was fine and everything was okay, it just happened suddenly last week.
If anyone has any ideas please help. I will really appreciate it.
Old Oct 16, 2022 | 07:56 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Need help!! No Fuel pump prime and no start but I just replaced few day ago
I have replaced :
fuel pump
map sensor
fuel filter
fuel injector
This is what broken means... before it was fine, now it is not. You have been throwing parts at it and you are frustrated.... I get it. Your problem is the ECU. When components inside it start going bad, you get the effect that you have described. Replacing capacitors may fix your issue, but the longer you wait to upgrade the caps, the greater chance that other components inside the ECU may be damaged making the ECU a lost cause. You can test this by substituting a known good ECU with the one that you have now... it doesn't have to be a P30 like you have now just to crank the car and idle it... but this will show the difference in overall behavior.
Get testing.
Old Oct 16, 2022 | 09:22 PM
theYBLEGAL's Avatar
Loved
I second this diagnosis.
And also add that IC17 is most likely the culprit, aka TA8903SN available on eBay and requires soldering. Capacitors should be changed out with ones of the same values as well.
Old Oct 19, 2022 | 01:00 PM
Stock95delsol's Avatar
it's a good idea to have a spare ECU anyway just in case.... but before I changed the ECU I'd replace that fuel pump again and check the rubber line coming out of it. I had one burst and it created a problem where it would get progressively worse until it just wouldn't start because the hole kept growing. I've also bought new fuel pumps and they were faulty. do the mechanical crap first because it's generally the moving parts that fail first.
touge killa
Sep 7, 2018 02:28 AM
motormike40
Aug 25, 2006 05:27 PM
SuperSteve737
May 29, 2006 01:39 PM
89civichatchback
Jul 1, 2005 08:28 PM
redcivicgsr
Jan 13, 2004 07:06 AM
