Knock sensor by pass
Old Oct 13, 2022 | 05:46 PM
limboacivic's Avatar
Default Knock sensor by pass
As the title read I’m doing a bypass since I have a z6 block gonna do the RadioShack method I’ve seen a couple times with a transducer. If anyone has done it before do you know if I can solder it directly to the knock sensor wire? I don’t wanna do the method where you run a new wire to the ecu I’d rather keep it simple and not look like trash.
Old Oct 15, 2022 | 02:56 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: Knock sensor by pass
try this: Bypass knock sensor. - Honda-Tech - Honda Forum Discussion
BILLisCHILL
May 8, 2008 06:40 PM
crxb16ftw
May 20, 2007 10:31 PM
EF_LSVtec
Apr 10, 2003 11:25 AM
93NXLUDE
Mar 5, 2003 06:32 PM
