Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
ENGINE COOLANT TEMPERATURE SENSOR/COOLING FAN
Old Oct 12, 2022 | 07:57 AM
Daisywheel's Avatar
Default ENGINE COOLANT TEMPERATURE SENSOR/COOLING FAN
I notice that my Honda civic 2006 cooling fan does not switch on when ect2 sensor is connected ( i.e when both ECT1 and ECT2 are connected) and engine temperature reaches 96oC (using OBII scanner) but switches on at 96oC when ECT2 sensor connector/plug is removed. what could be the reason/cause? I have experimented this on different occasions and noticed even at 98oC - 100oC, the colling fain doesn't switch on when ECT2 sensor is connected. I have replaced the ECT2 sensor with OEM but the issue still persists.
Anyone with clue about how i can resolve this issue should come to my aid. I have run out of idea.
Old Oct 13, 2022 | 08:41 AM
CarParts.com's Avatar
Default Re: ENGINE COOLANT TEMPERATURE SENSOR/COOLING FAN
Hello,
Do the fans come on with the A/C? The fans aren't designed to come on until the coolant temperature is 97 degrees Celcius, so the coolant temperature might not be warm enough to trigger the fans.
Old Oct 13, 2022 | 11:51 AM
Daisywheel's Avatar
Originally Posted by CarParts.com
Hello,
It came on only when ect1 is connected. And also when a/c is on. But it doesn't turn on when ect1 and ect2 are connected.
Old Oct 13, 2022 | 04:28 PM
Ryanthegreat1's Avatar
Fans cycle by ECT2 temp when it is available. Do you have scan tool that can show you what ECT2 is reading? Could be a bum sensor.
Old Oct 14, 2022 | 08:33 AM
As mentioned above, if the coolant temperature is getting hot enough to trigger the fan, you'll want to check for a faulty sensor. There is a TSB that indicates ECT2 could have loose or corroded terminals: https://www.tsbsearch.com/Honda/09-092
97civicdx
Jul 20, 2010 05:04 AM
Simmerman
12
Sep 18, 2007 07:05 PM
accorracer
Sep 19, 2004 05:35 PM
Ladies Man
Jul 14, 2001 09:35 PM
