99 Accord V6 - 150k tuneup
Old Oct 11, 2022 | 07:11 PM
tonightwetaco's Avatar
Loved
Default 99 Accord V6 - 150k tuneup
Hello and thanks for taking a look at my thread.
1.) I have a 99 Accord v6. I believe that means it has the Acura engine, is that correct?
2.) what should a tuneup cost roughly? What would be a total ripoff?
3.) should replacing the PCV be part of the tuneup?
4.) should i give the mechanic any special tasks?
5.) Also, while it happens seldomly I have noticed I will start the engine and it will cut out after a bit of shaking. My mechanic suggested I not let the fuel level get too low as that could be the cause. He said if its a sporadic issue he wouldn't bother looking for a problem at this time. Does anyone have any thoughts on this intermittent issue? I thought maybe it was the battery because it happened twice after leaving the car with the hazards on for 20 minutes. Other times it has happened I could not see a pattern. All in all it runs great though and I figure a tuneup is warranted for preventative maintenance.
Last edited by tonightwetaco; Oct 12, 2022 at 05:37 PM. Reason: making it more better
Old Nov 28, 2023 | 05:20 AM
Loved
Default Re: 99 Accord V6 - 150k tuneup
I went ahead with the tune-up....
Derek Robertson
Jul 5, 2017 04:26 PM
