B18b1 cam bolt broke inside deep side what size of heli coil do I use
8mm x 1.25 pitch... however, the reason that the bolt broke is because it was too long, so leaving a piece inside the cam will set you up for the same problem again. You MUST extract the bolt before repairing the camshaft end. B18B cams are plentiful and cheap... why don't you replace it ?
minituner
Jun 11, 2016 11:51 PM
paopao
Nov 12, 2005 06:07 PM
