Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Lean misfire under 3k rpm
Old Oct 7, 2022 | 02:38 PM
courterEp3's Avatar
Default Lean misfire under 3k rpm
I have a 2002 civic si with the stock k20a3, I started to get a bucking/hesitation when the engine is under load while under 3k rpm. There are no codes whatsoever so I borrowed my co-workers obd2 scanner that shows live data.
short term fuel trim drops to -12 whenever the misfires start, will have upwards of 60 misfires in one occurrence. All sensors seemed to be operating as expected until I saw the bank 2 o2 sensor voltage is dropping to 0 for very short moments of time, maybe a half a second or less. Bank one stays normal reading slightly rich when bank 2 reads crazy lean.
It’s leading me to believe bank 2 sensor is about to die, but I wanted to make sure there are no other possibilities before I start throwing parts at it as I have a history of buying everything I don’t need first 💀
Any help would be greatly appreciated.
ylekyote
Honda CR-V & Element
Apr 18, 2020 02:04 PM
Hypochondriac
May 7, 2018 10:49 AM
lpetrov
Jul 30, 2015 08:01 PM
cpennington89
Feb 20, 2015 05:33 AM
scratchline20
Aug 9, 2003 10:37 AM
