GSR swap fluctuating/high idle
Old Oct 5, 2022 | 02:46 PM
CheekySquid's Avatar
Default GSR swap fluctuating/high idle
I have gsr swapped civic and I'm having some problems with the idle. On cold start it will idle between 1500-2000rpm and when warmed up it will usually fluctuate between 1000-2000rpm but sometimes it will stay at 1000rpm which I believe is still considered high. The car has a skunk 2 intake manifold on which means it doesn't have the butterfly valve manifold but is still on a stock p72 ecu, could this be the problem? does it need a tune?
Old Oct 6, 2022 | 02:29 PM
1990IntegraLS's Avatar
Default Re: GSR swap fluctuating/high idle
IACV, idle air control valve...dirty maybe. I had the same on my gsr swap, but I kept the OEM 2-stage intake, so maybe not....and used a hondata p72. That also helped.
Old Oct 9, 2022 | 02:44 PM
How can I diagnose the IACV? I tried the carb cleaner trick to find vacuum leaks and if I spray below the throttle cable area the idle will rise which made me think I have a bad throttle body gasket. However, I'm able to stall the engine by covering the throttle body with my hand, does that mean it is not a vacuum leak problem?
Old Oct 9, 2022 | 03:38 PM
It's typical just to take the iacv...and the throttle body off and clean them both. There's no garrantee that'll solve the problem, but they probably need it. Replace gaskets and sensor o-rings.
Unless you installed the manifold and did it then.
Then follow the idle adjusting procedure, timing too.
Another thread that goes along the same lines:
https://honda-tech.com/forums/tech-m...rched-2044651/
Old Oct 9, 2022 | 03:58 PM
What is the proper idle adjusting and timing procedure? I'm pretty new to all of this.
Old Oct 9, 2022 | 04:04 PM
If you don't have a good manual, get one. Helms has the procedure.
Keelayy
Feb 20, 2020 05:24 PM
Nerdskateful
Dec 4, 2014 12:20 PM
rwcdrums
Aug 1, 2007 05:59 AM
freddy_hung
Acura TL, RL & ZDX
Nov 25, 2005 03:07 PM
Makdaddynuge
23
Sep 3, 2005 03:04 PM
