dumb question
Old Oct 4, 2022 | 10:37 PM
MechUnion's Avatar
Default dumb question
Changed my valve cover gasket (D16Y7) about a month ago to (successfully) solve a leak between it and the head. Checked my oil today and noticed a small buildup of oil around the edge of the spark plug wire (only on cylinder #1) where it meets the upper lip of the plug well. I haven't seen it there before, even after said gasket change.
I'm not concerned, more so curious because this is bizarre and I've never seen it before.
Old Oct 5, 2022 | 03:58 PM
98civdx's Avatar
Master Detailer
Default Re: dumb question
Did you replace the spark plug tube grommets?
Old Oct 5, 2022 | 05:52 PM
MechUnion's Avatar
I did. Unless I somehow did it incorrectly I'm not sure why the leak would happen.
To clarify, there is no oil in the well or on the threads for the plug. It is only on top of the valve cover in the aforementioned place
Old Oct 6, 2022 | 01:19 AM
DiogoLoureiroPT's Avatar
It kinda depends on the quality of the gasket... Let's say that the quality control of aftermarket gaskets isn't very constant. Sometimes a little RTV is a must to solve those leaks. I've replaced several vtec gaskets and even honda gaskets sometimes start leaking right after install
Old Oct 6, 2022 | 05:26 AM
Boxbox's Avatar
Yep sometimes i put a little high temp rtv on both sides of my gaskets. Make sure you have a clean surface 👌
Old Oct 6, 2022 | 07:40 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
If it's the top of the well (by the sounds). The well gaskets in the valve cover others have mentioned, might be in the cover correctly but I find you need a small flat tip screw driver to get them around the spark plug well tube correctly. If not they catch the edge and don't actually go over the well tube properly and instead partly sit on top of the well tube not sealing it. If you don't see the full circumference of the well tube at the top, you've caught part of the gasket and not gotten it to completely go around the tube like it's supposed to.
ducsaim
Apr 15, 2020 09:10 PM
Joseph Michaud
10
Feb 14, 2017 08:13 AM
denierlexiese
Aug 17, 2015 07:03 AM
zaida08bk
Jun 26, 2014 09:06 AM
rockwilda
Jun 9, 2003 09:52 AM
