Ef real lca subframe mount broken
Old Oct 3, 2022 | 09:12 AM
Mr Berry's Avatar
Default Ef real lca subframe mount broken
Hey everyone! I'm looking at an ef that I want to buy, however it smacked a curb and where the rear lca attached to the frame it bent and tore, I know a good welder, but has anyone had this problem? And how could I fix it? Unfortunately do not have pictures. I circle what sheared off in this photo, is it possible to make a bracket and weld it back on?
Old Oct 4, 2022 | 11:22 AM
TacoCat's Avatar
5 Year Member
Default Re: Ef real lca subframe mount broken
The front lower control arm mount point is not directly mounted to the frame. The LCA mount point is a part of the cross member so you just need to get a new crossmember. Look around at junk yards or online. However, be sure you get a manual steering rack version as the powered rack cross member found on some civics is different than the manual one.
dr_latino999
May 14, 2011 05:55 PM
deschlong
Feb 14, 2011 09:54 AM
sikciv666
Feb 18, 2009 10:20 AM
yellowhonda88
Feb 4, 2008 05:16 PM
