Ball joint wont stop spinning
Old Sep 28, 2022 | 12:47 PM
Jack Gorlick's Avatar
Default Ball joint wont stop spinning
that ball joint wont stop spining ,i tryed jacking up the suspenshion and forceing it down with a braker bar.
cant loosen or tighten it
also hit it with a hammer a few times
Old Sep 29, 2022 | 11:21 AM
91akira's Avatar
Default Re: Ball joint wont stop spinning
Remove the upper control arm with the knuckle. Weld a nut on top of the ball joint. Use an open wrench for the welded nut and then use an impact to remove the castle nut. Good luck
Old Sep 30, 2022 | 12:33 PM
Sic_DA_Nine's Avatar
are you replacing?
if so, destroy the boot, take some vice grips and hold onto the shaft, then blast it off with impact
Old Oct 30, 2022 | 07:31 AM
NVturbo's Avatar
O.G. triple O.G.
Originally Posted by Sic_DA_Nine
are you replacing?
done that a few times myself....upper and lower control arms.
Old Oct 30, 2022 | 07:43 AM
i figured it out thanks for the help guys
KraKimus
Jul 18, 2009 12:32 PM
CARMA_626
Feb 22, 2009 06:48 AM
integra15
Aug 12, 2006 10:04 PM
gumbybum
Jan 31, 2003 11:11 AM
wildstallion
Jul 23, 2002 02:09 AM
