Pablomg's Injectors aren't working!
Old Sep 28, 2022 | 02:45 AM
Pablomg's Avatar
5 Year Member
Default Pablomg's Injectors aren't working!
Hei!! My injectors died!
12v ok
negative thermostat ok
fuses ok
Other ecu
Other main relay
Has ignition
all sensors has ohm
I dont know what more !
Old Sep 29, 2022 | 03:16 AM
ohisofly's Avatar
Default re: Pablomg's Injectors aren't working!
Are you getting power to the injectors? If you aren't the best with a multimeter, a noid light is an easy way to figure that out
Old Sep 29, 2022 | 03:18 AM
Pablomg's Avatar
5 Year Member
yes! 12v ok!
Old Sep 29, 2022 | 03:45 AM
ohisofly's Avatar
Have you tested your injector grounds then to the ECU? Checked for continuity between each of those wires at the injectors and at the pin on the ecu plug side? I noid light would also confirm that
Old Sep 30, 2022 | 08:48 AM
Pablomg's Avatar
5 Year Member
ground not is ecu/injectors in thermostat?
Old Sep 30, 2022 | 10:10 AM
DaX's Avatar
DaX
Loved
Community Favorite
No...the ECU ground is at the thermostat. But to fire the injectors, the ECU completes the ground for the injector circuit.
Honestly, I would follow @ohisofly 's advice and use a noid light at each injector - that would be the simplest test.
Old Sep 30, 2022 | 12:13 PM
Pablomg's Avatar
5 Year Member
i havent this tool! For fast test i can put manual ground ? How i do it?
Old Sep 30, 2022 | 02:41 PM
DaX's Avatar
DaX
Loved
Community Favorite
Im guessing you are not in the USA? Do you have an auto parts store near you that rents tools? Thats where i have rented a noid light before.
No, you cannot do a manual ground, as that is the side of the circuit that is rapidly switched to fire the injectors.
Old Oct 2, 2022 | 06:04 AM
Pablomg's Avatar
5 Year Member
All ok! it has an aem 320lph pump was not completely submerged, so even if it shows gasoline it does not suck xD ( i didnt know used car )
johncleaver
Sep 16, 2022 01:18 AM
EF'n Sedan
Nov 26, 2016 06:33 AM
RACEPAK
Apr 29, 2010 01:42 AM
RACEPAK
Apr 29, 2010 01:41 AM
A13sechatch
Mid-Atlantic (Sales)
May 25, 2009 08:26 PM
