Honda S2000 Honda S2000
S2000 Vtec Failure P1259
Old Sep 21, 2022 | 04:44 PM
Noobs2kk's Avatar
Default S2000 Vtec Failure P1259
Any help with trouble shooting Vtec failure code? I’m thinking it’s the stripped wiring, should I get a whole new solenoid with a new harness? Any ideas on how to fix?? (See images)
Old Sep 21, 2022 | 09:33 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: S2000 Vtec Failure P1259
Your Solenoid appears to be fine... the problem is the broken wire at the VTEC Pressure Switch. I would cut the wires back a bit from the original grey plug in your photo and graft on a replacement plug so the wire connection junction is not right at the plug, but a few inches back from it. This plug is used commonly in many different Honda/Acura engine applications, so you can cut one from a donor/parts engine harness from your local pick-a-part.
TheMuffinMan
Honda S2000
13
Jan 16, 2013 09:25 PM
8k-red-DC2
Jun 20, 2006 08:25 PM
daddymaxx
Honda S2000
21
Oct 31, 2003 02:01 PM
