What coolant should I use
Old Sep 20, 2022 | 07:56 PM
Farquea's Avatar
5 Year Member
Default What coolant should I use
I'm just putting together a list of fluids to change and can't find much info on recommended coolant. Does it matter enough that I should be looking for genuine Honda coolant or stick with the OEM or Prestone brands that I'd find in my local big box store?
Old Sep 20, 2022 | 08:15 PM
BeardedBaldy's Avatar
Default Re: What coolant should I use
I'm pretty sure the usual stuff from an auto parts store is good enough. If any doubt, you can always ask one of the workers, their computer system will have the correct info on what coolant your motor takes. More than likely, whatever is on the shelf, that says "Import/ Honda",
Personally, I'm using distilled water + Water Wetter, but I live where it doesn't get below freezing. But, my car has a hard time warming up to operating temperature now, i.e. my cooling system is hyper-efficient now haha.
Just use whatever you find, don't sweat it too much. There aren't very many fluids you need to change anyway;
Brake fluid
Engine oil
Transmission fluid
Clutch fluid, if manual transmission
Coolant
Atauto
Honda CR-V & Element
Mar 9, 2015 03:31 PM
dth0ng69
10
Jul 8, 2009 07:49 AM
CRXed
Jun 26, 2004 08:19 PM
deviant1
Oct 24, 2002 07:25 PM
Duck Sauce
Nov 23, 2001 08:49 AM
