Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Won’t start after thermostat and fan switch VIDEO/pic
Old Sep 17, 2022 | 01:45 PM
Kingme413's Avatar
Default Won’t start after thermostat and fan switch VIDEO/pic
So my car was overheating . So I decided to change the thermostat and the fan switch. I changed the thermostat without draining it but it wasn’t much coolant . I’m thinking maybe the coolant got into some open wires under it which I’ll show pics . When I put the key in to turn it , the dash light come on and when I try to start it I get a click and the battery dies . It doesn’t go back on until I mess with the cables or something . I don’t know what the hell is going on . Please some help here
These are the wires that are open and I don’t know if maybe that is causing it idk what those wires are
Old Sep 17, 2022 | 01:50 PM
Kingme413's Avatar
Default Re: Won’t start after thermostat and fan switch VIDEO/pic
so I tried to post the video of what happens when I try to start the car but I couldn’t so I made a YouTube short.
check it out and please give me some ideas what to look at , thinking of changing battery cables or checking the ground of the thermostat.
ALSO THE BATTERY IS GOOD . I tested it at 12.6 volts . I tried to jump the car it didn’t work . It’s just weird how it dies when I try to start. All I can think is a bad connection and it’s not enough to start . The starter and alternator were changed not too long ago as well.
Old Sep 17, 2022 | 01:51 PM
Kingme413's Avatar
Also in the video you can’t see as well but after I attempt to start it the first time , the dash lights no longer come on when I try to start it again. Sometimes a faint brake light will come on
Old Sep 17, 2022 | 03:19 PM
Kingme413's Avatar
Bump
Old Sep 17, 2022 | 09:08 PM
Ryanthegreat1's Avatar
Janky battery terminals aren't helping anything. Did you remember to put the ground back on the thermostat housing?
Old Sep 18, 2022 | 07:56 AM
Kingme413's Avatar
it’s the terminals . After a while of trying to find out I just tapped the terminals with a wrench a few times , started right up. I knew I needed to change a cable but I’m going to start with terminals and see how it goes .
faystontj
Jun 21, 2022 08:47 PM
spens 91 Ef
Mar 3, 2009 03:36 PM
Vtec's My Anti-Drug
Apr 22, 2007 04:00 PM
ahh sanga
Jun 23, 2004 05:42 AM
HybridKOOP
Aug 14, 2002 11:08 AM
