‘96 Accord F22B ivtec Stalling while Accelerating
Hi Everyone,
I’ve got a F22B ‘96 Honda Accord that stalls when i accelerate and the car is warmed up. Issue started about 4 months ago. I’ve changed fuel pump, the ignition distributor, plugs, air filter.
First instance is when i drive and i’m in 4th gear around 80 km/h, car is warmed up, it stalls, accelerator doesn’t work or car jerks when it works, but i dont loose power from the engine, so i let it roll for a bit and return to 2nd or 3rd gear, and after some seconds, it responds to acceleration again.
Second instance is when i’m parked, and the car is warmed up, rev the engine and keep it at 2500 rpm, then in about 2 minutes, it drops to about 1800 rpm, when i match the 2500 rpm by accelerating, after a few seconds, it goes to about 3000 rpm and i have to release the accelerator to match 2500 rpm again.
I’ld appreciate your suggestions on what next to check.
Please note the car hasn’t got an OBD port and i dont have CEL on.
BlueDragon31
Sep 12, 2021 04:06 PM
theoaksguy
Feb 3, 2013 01:22 PM
