K24-Integra swap brakes/hub
Old Sep 9, 2022 | 01:07 PM
taschw6's Avatar
Default K24-Integra swap brakes/hub
I have a k24a8 that I'm swapping in a 1995 gsr integra. I have the axles from the accord and I know that the integra has only 32mm axles so I will definitely need to change the hub and knuckle? If so what will fit on the integra? Any setup as long as it is 36mm? I'm just trying to do research and haven't found much that isn't old and not many are on kswap integras only bseries any info is appreciated as I'm still learning as much as possible. Thanks!!
Old Sep 9, 2022 | 09:53 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: K24-Integra swap brakes/hub
Order a pair of 36mm hubs from Karcepts and press them into your knuckles.
Old Sep 13, 2022 | 05:03 AM
taschw6's Avatar
What about larger brakes? Is it possible with this method and Is it necessary? Also are there any problems with it?
Ahh Vtec
Jan 4, 2008 08:23 AM
gook
Jan 4, 2006 07:33 AM
85mm LS VTEC
Feb 22, 2005 10:26 AM
litlekikr
Mar 2, 2003 03:17 PM
civichopeful
Oct 13, 2002 03:42 AM
