Remote Wire does not have Power and RCA have Noise and Front Right Speaker not workig
Hello
I have Installed Pioneer ZF-9350 BT
With 3 Amps Separate for Front Rear and Sub
I checked with volt meter their is NO Voltage coming from Remote Wire
Also RCA have alot of Noise as well Right channel RCA Front and Rear both have no Sound.
What should i do?
Is there any fuse in Remote wire?
What should i do?
I'm guessing the headunit you bought is USED? As for sound interference...are you using good RCA cables? Are they ran on the same side as the (amp) power wires??
i bought Brand New Unit
first it was working perfect but once RCA touched the ground after that no voltage in Remote Wire and very noisy and Right front rear no Sound
Understeer
Audio / Security / Video
Jul 29, 2002 06:47 PM
