Troubleshooting: 2.7 V6 Vibration at idle
Old Sep 6, 2022 | 05:32 PM
LynusR's Avatar
Default Troubleshooting: 2.7 V6 Vibration at idle
I had the front motor mount replaced and now the car shakes really bad in idle. In park, neutral its calmer but in reverse is the worst.
I am assuming either my rear motor mount got jacked up (figuratively speaking) when he was doing the front one or the front one isn't quite right. It looks like OEM on the front.
Is just the rear one vacuum controlled or is the front one as well?
This is the front one that was replaced.
Old Sep 8, 2022 | 02:14 PM
LynusR's Avatar
Default re: Troubleshooting: 2.7 V6 Vibration at idle
Bumping this for attention, just majorly updated the post.
Old Sep 8, 2022 | 06:14 PM
Ryanthegreat1's Avatar
What model and year is that? I don't recognize that engine.
Anyway could be that the new mount is stiff. Also there is an order to how mounts get tightened down so none are in a bind and cause vibrations.
Generally you can just loosen off all the mounts, rock the engine and few times against the parking pawl and then tighten everything back up in this new relaxed state.
Old Sep 12, 2022 | 10:24 AM
LynusR's Avatar
Hey sorry, I didn't see the reply. It's the 2.7 V6 for the 25th anniversary Honda AHonda.
We might have found the issue. After calling the place that did the replacement they said they went with an aftermarket, most likely a solid mount... I know these are supposed to have the hydraulic ones. Mechanic said he's fix it.
emmaturecb7
Jan 10, 2008 04:56 PM
pumafeet10
Dec 9, 2004 05:33 AM
sinfulDB1
May 2, 2004 06:33 AM
Vader
May 14, 2003 12:30 PM
Vader
May 13, 2003 10:26 AM
