How to reset dashboard lights without infotainment screen?
My car is a Honda Civic 2018 without infotainment screen. The screen is only for audio. I replaced rear brakes and one of the rear calipers, after I made some mistakes (see my previous post if curious). I used a bi-directional scanner all the way while I was making progress. The scanner was giving a few error codes on the brakes, as expected. When I finished the job, I ran the scanner again and it didn't show any error code. All was good from its perspective. I can apply and release the parking brake fine. I drove the car, tested it with the new brakes, all looks great. My problem is that I now have several dashboard lights on and I need help figuring out how to reset them (see photos below) . I tried to disconnect the positive cable from the battery and press the break pedal before reconnecting it, without success. As I said, my car's screen is not the infotainment one that allows you to reset the dashboard lights. Notice that one of the lights is flat tire. All tires are fine and when I push the button to reset that light, it doesn't go away. Anyone has any suggestions? Thanks.
