90 civic crank no start
Do you have spark?
When you turn the key to the ON (not start) position, do you hear a click and does the CEL come on? If so does it go back off in about 2 seconds along with another click? If not then pull out your main relay and check the solder joints.
just replaced main relay, pump is engaging and hearing a click, check engine light goes off when engine is trying to turn over. I have another thread (the one below this one) explaining what I’ve already done and where I’m at. Very stuck though.
raider1qaz
May 17, 2014 06:38 AM
