Bisimoto header not lining up with exhaust pipe
Old Sep 1, 2022 | 12:47 AM
So_low's Avatar
Default Bisimoto header not lining up with exhaust pipe
JDM B20B in a 96 EK hatch, I have a Bisimoto header and running an Invidia exhaust. I have been trying to either make my own test pipe or modify the existing test pipe to fit to the header however im noticing that the header sits maybe 1/2 inch higher than the rest of the exhaust. What's the go to for connecting these pieces, all of the pipes ive tried sit crooked plus i have no bracket or flex by the header. Looking for either a pipe with a bend to weld to the header and bolt to the 3 bolt flange on the mid pipe preferably but open to any ideas
Old Sep 1, 2022 | 09:00 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Bisimoto header not lining up with exhaust pipe
You will have to fabricate the proper "Test Pipe"... and it is a good idea to find a piece of mandrel bent tubing to use so that you can create the "Jog" that is needed to keep it in alignment and not "sit crooked". Welding a bracket to the header might help... or you can integrate a piece of flex pipe into your "Test Pipe". A source for exhaust pipe should be able to help... like K-Teller.
If all this becomes too much trouble, I suggest you pick up a better header... there are PLENTY of them out there.
tealchief
Feb 23, 2009 11:36 AM
D-Rob
10
Feb 27, 2006 06:53 PM
SpeedMachine
May 7, 2005 04:04 PM
