Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Oil leak
Old Aug 18, 2022 | 02:36 PM
zeeshanzaki's Avatar
Default Oil leak
I have oil leak from lower timing cover side which hard to determine if it is from crankseal OR oil sump. Is there a way to find out which on one is leaking from.
It leaks around 50ml to 75ml after parking the car and whole control arm underneath socked in oil.
Oil leak from sump or crankseal
Old Aug 18, 2022 | 08:40 PM
Ryanthegreat1's Avatar
Default Re: Oil leak
Did you clean that area or is that how you found it?
If that is how you found it probably not the crank seal.
Old Aug 18, 2022 | 09:14 PM
The picture I posted is just for the reference, its not from my car. I found the oil dripping from that area.
Old Aug 19, 2022 | 04:55 PM
DCM1's Avatar
Looks like you’ll be changing a front main seal in the near future.
Old Aug 19, 2022 | 05:20 PM
Don't forget a repair sleeve at this age. Crank is probably grooved where the seal runs.
pjr710
Feb 6, 2009 10:23 AM
Serenity Now!
Jan 29, 2007 06:31 AM
hotstuffjsn
Mar 9, 2005 07:11 AM
deepnite
Oct 9, 2002 01:46 PM
