Based on the circuit diagrams, '03-05 should be the same if they are the same trim level. If they are not the same trim level, then there may be differences.
Different trim levels gauges:
'03-05 GX
'03-05 DX
'03-05 HX, LX, EX
Do you know what trim level is your original and the replacement trim level?
If you want to use the replacement cluster, you'll have to figure out or guess whether it is a GX or not GX (but, HX, or LX, or EX).
Then you probably will need to de-pin the wires and and re-pin them in the connectors. There are youtube videos and Honda guides on de-pinning on the internet.
These are the 3 pin-outs for the different trim connectors.
