Re: introduce myself
Old Aug 15, 2022 | 08:40 PM
95ejuno's Avatar
Default Re: introduce myself
Hello, my name is greg I live in az I recently bought a 95 Honda Civic ex coupe ej1 with a b16a2 swap. I am new to fixing/building Jdm cars I’ve never owned a Honda before, but glad I finally did it. Having said that I have a few questions and thank you in advance for any advice/knowledge.
Pics:
it’s been a great car so far only problem I’m having is can’t pass emissions. I’m pretty sure the reason behind this is because I have major leaks were there use to be a cat which is now a bad wielded aftermarket test pipe.
pics:
This is just soapy water to view my exhaust leaks
My main concern is I have a lot of leaks so I narrowed it down
I have leaks at:
• inner tie rod bellows so I’m guessing my rack is going out I have a power one
• major oil leak the only place I can see it at it’s worst is behind this pcv black breather chamber box.
• major leak at my shifter seal linkage this one I’m most concerned about because ya I can see the seal has been cracked but there’s tranny oil leaking from the bolts so I’m not sure if that’s another issue also I see some oil around the oil pan but I’m not sure if I that’s just splatter from the chamber box when driving. Here are some pics Thanks for any advice/input.
pics:
I don’t know what happen here, but I took off distributor cap to replace and this was what it looked like when I took it off the rotor was broken in pieces too.
Here’s a run down of what I have as well thanks everyone.
oscar4605
Sep 18, 2021 08:29 AM
zemerin
May 15, 2014 08:19 PM
godnf8
Mar 1, 2007 09:57 AM
acewalker
Jan 15, 2006 09:13 PM
HondaEJ7
25
Jan 4, 2006 07:12 PM
