Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
How do I keep audio system on when starting the engine?
Old Aug 15, 2022 | 10:51 AM
Joshua5684's Avatar
Default How do I keep audio system on when starting the engine?
I often find myself waiting in my car, so I don't leave it idle, but I listen to music. When I start the engine, it interrupts the music for a while as the audio system restarts and reconnects to my phone via Bluetooth. Is there anything I can rewire to keep the audio system on when I start the engine?
P.S. I realize how trivial of an issue this is. No need to remind me.
Old Aug 15, 2022 | 12:25 PM
bumpstick's Avatar
Default Re: How do I keep audio system on when starting the engine?
The radio gets power from the accessory circuit (does not stay on while cranking). Cut that wire and hook it to an ignition source instead. Ignition stays hot while cranking
Old Aug 15, 2022 | 03:31 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
^^ That will not work.
Fuse No. 8 for the radio is already switched ignition power. It receives power when the ignition switch is in the Accessory (I) or ON (II) positions.
When the ignition switch is in the START (III) position, there is no power to Fuse No. 8.
A solution would be to use a capacitor and diode on the Yel/Red wire for the radio. See this youtube video:
Old Aug 22, 2022 | 10:37 AM
Joshua5684's Avatar
Thanks tech8. This worked!
sophiak99
Honda CR-V & Element
Aug 12, 2018 10:19 AM
kamran075
Mar 27, 2017 03:58 PM
joey_knuckles
Nov 16, 2004 04:06 PM
