HELP!! Car jerks in vtec and doesn’t go
Old Aug 14, 2022 | 08:54 PM
KisforKing27's Avatar
Default HELP!! Car jerks in vtec and doesn’t go
So my friend has a k20z3 with k24a2 block, for the last couple months the car has been jerking hard sometimes before it hits vtec and stays where vtec kicks in and sounds like it’s hitting rev limiter
When we disconnect TPS and connect it again it stops doing it but only for a while then it starts doing it again and we have to adjust it again, this is his 3rd TPS sensor because we thought it was a bad one. We then adjusted it by twisting it 180 degrees and it seems to work longer without having any issues
HELP!!!!!
Old Aug 15, 2022 | 04:57 AM
Ryanthegreat1's Avatar
Default Re: HELP!! Car jerks in vtec and doesn’t go
Are you using an aftermarket throttle body?
Old Aug 15, 2022 | 08:05 AM
Yes he is, I was thinking throttle body must’ve been the issue and try switching mine with his
RR_si
Honda Civic (2006 - 2015)
Jan 23, 2010 11:53 AM
CRXHFB16
Jun 6, 2007 02:22 PM
xtreme-customz
Nov 8, 2005 06:03 PM
JennG35
Nov 11, 2004 11:13 PM
