A/C question
Old Aug 11, 2022 | 01:07 PM
steeebo's Avatar
Default A/C question
2000 civic coupe
Car shakes at idle when ac is on.
is it the compressor going bad ?
Old Aug 11, 2022 | 05:28 PM
Chance EG's Avatar
Default Re: A/C question
Is the AC still cold?
What is your RPM dropping to when you turn the AC on? Do you notice the shake when you're driving, or only idling at a stand still?
Old Aug 13, 2022 | 04:21 PM
Knownworldwide's Avatar
Motor mounts are most likely shot. However chance’s ^ questions are definitely more likely to give you a more accurate answer.
Old Aug 30, 2022 | 05:10 AM
steeebo's Avatar
As if it wants to stall out at idle but is dine when driving, ac is still cold.
steeebo's Avatar
Hmmm maybe…I’ll be asking a mechanic soon.thanks.
Old Aug 30, 2022 | 05:27 AM
Chance EG's Avatar
You don't have an AC issue, you have an idle issue. Check & clean IACV, there should be a screw to adjust idle on your throttle body as well.
Edit: Adjust the idle while you have the AC on.
Old Aug 30, 2022 | 11:29 AM
steeebo's Avatar
alright I’ll try that … you think that’ll solve it for sure?
Old Aug 30, 2022 | 12:11 PM
Chance EG's Avatar
I think it's likely. You should raise the idle when the AC is on, aim for 1000-1200RPM.
Old Aug 30, 2022 | 05:27 PM
steeebo's Avatar
could it have air in system? 1000-1200 seems a lil high
Old Aug 30, 2022 | 05:28 PM
steeebo's Avatar
i will try raising the idle with the AC on soon and post updates. Thanks.
liljohnson
Aug 13, 2004 11:23 PM
D16OnTop
Dec 1, 2003 02:36 PM
Aaron Taylor
Jul 5, 2003 11:14 PM
