Backfiring out of the intake tdc and 150 psi
Old Aug 8, 2022 | 02:20 PM
1320vickers's Avatar
Default Backfiring out of the intake tdc and 150 psi
I’m getting a weird issue out of nowhere the motor is not out of time the compression is 150 on all 4 cylinders cranks over normal until it goes to fire then the starter struggles to turn it over and pushes air thru the intake I have the Hondata crp kit and I’m using s300 v3 same tune as when it was running fine
Old Aug 9, 2022 | 11:57 AM
Default Re: Backfiring out of the intake tdc and 150 psi
Any help it slows down the cranking when it hits and then backfires could it be a ignition issue if it’s firing at the wrong time
Old Aug 15, 2022 | 09:56 AM
Maxcapacity's Avatar
Should double check your timing belt, check it's tension and set it to TDC for cyl #1 and make sure it didn't skip teeth on the cam/cams checking the alignment marks.
Old Aug 15, 2022 | 01:55 PM
I re timed it just be sure I think it’s the Hondata cop box firing all cylinders at once
Wazup
Honda Civic (2006 - 2015)
12
Jul 25, 2007 07:33 AM
1234567899876543211230
22
Aug 12, 2006 02:07 AM
pomansouth01
23
Jul 12, 2006 05:12 PM
zeroz
Apr 16, 2005 05:16 PM
JDMvision
Jul 25, 2004 07:45 PM
