Built b16a nitrous build
Im buying a built b16a and was wondering if this setup is good for nos also can i run this setup naturally aspirated?
This is what it comes with:
JDM B16A 81.25mm bore
CP pistons 9:1 compression 81.25mm
Eagle H beam rods
ACL bearings
ARP rod bolts
ARP head studs
Honda oem engine gasket kit
Honda oem head gasket
Honda oem distributor
NGK spark plug wires
Super tech valves, springs, retainers,
Civic type r camshafts
Buddy club cam gears
Precision 880cc injectors
Honda oem water pump and timing belt
Eagle H beam rods
ACL bearings
ARP rod bolts
ARP head studs
Nitrous pairs better with high compression. Pairing 9:1 pistons with CTR cams is also a bit odd.
Based on the whole parts list plus the fact it's coming with 880cc injectors, I'd say it's more suited for a mild turbo build than nitrous. All you'd have to do is change the pistons if you wanted to run nitrous with good results.
stockbee
11
Oct 29, 2007 01:15 PM
ExospeedAMcrx
Apr 14, 2005 09:37 AM
