Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Odyssey rear hatch not opening 2012
Old Jul 27, 2022 | 12:40 PM
vjfromgt's Avatar
Default Odyssey rear hatch not opening 2012
My 2012 Odyssey rear hatch is not opening.
I replaced the latch,
Dealer replaced the handle.
I checked fuses under driver foot,
I checked fuses to the right of passenger foot.
I checked fuses on the left of cargo area.
No bad fuses found.
Dealer charged me $600 for a new handle and the problem is still there, they wanted $500 more for latch which I instead did myself and the problem is still there.
Now the dealer wants me to pay them $500 to check wiring between the slider and the rear hatch.
Slider unlocks fine.
both front door unlock fine.
Old Jul 30, 2022 | 04:50 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Odyssey rear hatch not opening 2012
It may be an issue with the power tailgate control unit or wiring.
Signals from the either the driver's dash tailgate switch or the outer handle switch are directed through the power tailgate control unit before they go to the tailgate closer unit.
With the tailgate opened, disconnect the black 2 pin Connector A from the tailgate closer unit, then check if there is momentary power on the red wire on that harness connector when you try to operate the tailgate with a switch or remote.
s13hero
Jan 20, 2010 08:30 AM
Braco11
14
Feb 23, 2007 01:39 PM
pizzle
May 26, 2006 10:32 AM
JdMCiviCCupE
Dec 7, 2003 12:16 PM
OmegaLS
Sep 19, 2003 06:15 PM
