DA9 Integra Manual Swap Axles
Old Jul 27, 2022 | 09:23 AM
KatagiriWorks's Avatar
Default DA9 Integra Manual Swap Axles
Sorry for asking a question that's probably been covered already - I've not been able to find an answer anywhere.
When doing a manual transmission swap on a DA9 LS, is it possible to use a half shaft from a DC chassis LS if I use DC axles? Finding a DA9 half shaft in decent condition is proving challenging.
I'm keeping the stock B18A1, and the transmission I'm using is a Y1 cable trans from a CRX SIR, if that matters.
Old Jul 27, 2022 | 11:14 AM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: DA9 Integra Manual Swap Axles
DC2 axles are about 3/16" longer than DA axles... if your car is lowered any, the DC2 axles will likely bind in your application.
Old Jul 27, 2022 | 11:54 AM
Thank you, that's really helpful.
That brings up one question though. Most aftermarket OE replacement passenger side axles are listed as 1990-01 fitment. This leads me to assume that DC and DA axles just vary in length/construction on the driver side.
Actually, I may have made a mistake in my OP. I didn't mean DC2 axles as in DC type R axles, just DC chassis LS/GS axles - DC1/DC4/DB9 etc. Just edited the OP to reflect this
Old Jul 27, 2022 | 12:53 PM
Chrisfrom1986's Avatar
If you need a DA halfshaft I have one I don't need.
EG6_978
Mar 23, 2010 11:32 AM
JUN.
Feb 5, 2008 02:41 PM
nomotor
Oct 20, 2004 05:38 PM
d!zZy
Feb 3, 2003 10:59 PM
XANDER-666
Oct 7, 2002 12:04 PM
