Window went down, won't come up
Old Jul 26, 2022 | 02:00 PM
Loyalty1998's Avatar
Default Window went down, won't come up
1994 Civic EX Coupe. Passenger side window was rolled down, but it will not come up. I pulled the door panel and checked the wiring that goes to the motor and both wires are putting out 12 volts. The motor is brand new and I can hear it engaging to roll down, but not up. And the driver side works just as it should, so I've got no idea what's up with it.
Old Jul 26, 2022 | 06:13 PM
Maxcapacity's Avatar
Default Re: Window went down, won't come up
I would first remove the motor leaving it plugged in and then try it to see if the motor gear is actually moving both forward and reverse strongly (obviously one direction works) grab the gear by hand and try, maybe it's weak in one direction or there's some sort of restriction with the window regulator or if it's off it's track? Maybe the wheels are worn out and sticking? Was it working before with the new motor and just randomly stopped in the down position?
portugueboy10
May 17, 2016 08:23 PM
02EX
Jun 1, 2015 04:25 PM
GsRrrr
Jun 14, 2011 04:02 PM
sohc-8
Jan 11, 2006 12:12 AM
JDMNICA
Audio / Security / Video
Aug 25, 2005 06:42 PM
