Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
2007 Civic 1.8 O2 sensor, sensor 2 harness wire to connector, correct placement
Old Jul 26, 2022 | 01:37 PM
Coop747's Avatar
Icon5 2007 Civic 1.8 O2 sensor, sensor 2 harness wire to connector, correct placement
Harness to O2 Sensor #2 was found like this. Need to know which wire goes to what terminal of the connector. 2007 Civic 1.8 The sensor found on the lower front of the Cat, not the top.
Old Jul 26, 2022 | 02:15 PM
Chrisfrom1986's Avatar
Default Re: 2007 Civic 1.8 O2 sensor, sensor 2 harness wire to connector, correct placement
Old Jul 28, 2022 | 10:47 AM
Coop747's Avatar
That is the photo I've been looking for. However, I must be clear on whether or not what I'm looking at, is the right way, up or down, as it's hard to tell, due to the difference in the look of replacement connectors, vs the factory originals. Is that the connector from the harness or from the sensor? I'm using a "harness extenstion", that I bought on Amazon. It's connectors are not compatible with the factory ones, and the wire is heavier. So, I can either cut the connector off of the new O2 sensor, and swap it with the Amazon connector, or spend more money on a correct harness connector. I would prefer the later, however finding one isn't so easy.
Thank you!!
Old Jul 28, 2022 | 11:40 AM
Its the harness side connector. Go to the junkyard and cut one off.
Old Jul 28, 2022 | 12:58 PM
Coop747's Avatar
Perfect. Thanks!
lv6l
11
Apr 8, 2008 01:10 PM
_gurusan_
Aug 2, 2006 05:59 PM
B_1_8_hatch
Sep 3, 2003 08:20 AM
