Rear wheel hub question 🙃
I want to take my trailing arms apart so the wheel bearing hub has to come off.
The disassembly part isn’t really the problem but can I re-use the wheel bearing hub knowing that sometimes the inner part of the bearing can stuck to the trailing arm? Or doesn’t that matter if you put it back together?
Asking this because the bearings are okay and don’t need replacement.
It’s for a EK4.
It’s for a EK4.
Just be careful with it if it does stick and when assembling back together just be careful, don't smash it on, use the nut to press it back if needed. The bearing will be fine to reuse
