Bent valves Honda accord euro k24z3
Hey guys need some help finding out a problem after we did a DIY timing chain job on my friends honda accord euro 2010. I'll repost from another forum:
Any helpful info would be greatly appreciated. Thanks!
Hey all new to this forum. I did a timing chain DIY with a friend's honda accord euro 2010 LX with the K24Z3 engine (we did it together) and the valves were damaged after he cranked the motor a couple times. We made absolutely sure the timing chain was timed with the timing marks on both cams and the crankshaft at TDC positions on the gold links while using cam locking pins. And the chain tensioner was set about 3-5 clicks after we let the pin out. We spun the crank a couple times clockwise with little resistance. And we also made sure we put everything back together as it were before like the belt, pulleys, rocker cover etc. The diagnosis of the bent valve was determined by my friend's local mechanic which I would assume he did a compression test of all 4 cylinders.
What could have caused the valves to be bent?
Did the valves hit the pistons? If so did we miss a crucial step when doing the timing chain?
Did we need to have done a valve lash adjustment after doing a timing chain?
Is there more potential damage than just the heads?
Does the lower block need to be pulled apart and inspected as well?
Any help would be greatly appreciated and if someone could shed some light on where we went wrong with this DIY. Thanks!
Was the mechanical timing verified after releasing the chain tensioner and rolling the engine over by hand?
Any chance you have pictures of the way you had the timing marks lined up?
No pictures. And by rolling it over by hand do you mean spinning the crank clockwise a couple times? If so then yes. But I believe I have found our crucial mistake. But to confirm if we match the cam marks(two dots) to the crank marks(both arrows and one dot) does that mean cylinder 1 is at TDC on the compression stroke? Could we have put the chain on the wrong TDC by accident (exhaust stroke)?
I just replaced my tensioner yesterday. The old tensioner had two grooves exposed. Cam wheel was sitting on third groove. I set the new one to same configuration. Now when I start the engine, it plays whistling Dixie!
