Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
EP3 Starting Issue
Old Jul 19, 2022 | 01:02 PM
N21BUT's Avatar
Default EP3 Starting Issue
Need some advise please
Discovered a problem with my ep3 2002
Went out the other day to work and it drove completely fine. Went to start it back up after work and nothing happened. There was no click and it wouldn’t start.
Thought it was the starter motor as it’s been on and off in the past. I changed that this evening and it still isn’t working.
Checked power to the starter motor and the power was there but it doesn’t crank. Any ideas??
I have had to put a wire on the starter signal switch and touch it to the battery for my starter motor to work so the car starts.
Any help would be much appreciated! Thank you.
Old Jul 19, 2022 | 01:49 PM
Ryanthegreat1's Avatar
Default Re: EP3 Starting Issue
Rubber nub on the clutch pedal has cracked and fallen out and now the starter inhibitor switch on the clutch isn't getting pressed.
Old Jul 19, 2022 | 02:09 PM
N21BUT's Avatar
hi do you have a link or a photo??
Old Jul 19, 2022 | 02:38 PM
https://www.hondapartsnow.com/parts-...sis/pedal.html
Part #10
There are two on the clutch pedal arm.
https://www.youtube.com/watch?v=nvaBLDeCVQ8
Old Jul 19, 2022 | 10:45 PM
N21BUT's Avatar
so if I don’t have the cruise control mine should be the bottom sensor switch? So I don’t have to take the full clutch pedal assembly off?
Old Jul 20, 2022 | 06:28 AM
Poke your head in there and look? It is probably the upper stop.
Old Jul 20, 2022 | 08:04 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
The clutch starter interrupt switch is the TOP one... the lower one, which is much easier to get to, is the cruise control release switch... unfortunately. There are ways to install the stopper in the pedal without removing the pedal assembly, but it is difficult and tricky. Some find it easier to remove the pedal.
Old Jul 20, 2022 | 09:44 PM
N21BUT's Avatar
tbh with you I’ve had a good look and it doesn’t seem to have a top senser? I’ve even had the seat out to check 😑
Old Jul 20, 2022 | 09:55 PM
N21BUT's Avatar
I’ll have to have another look today 😐😐😐
DJz3r0
Sep 7, 2012 12:33 PM
slowcxhatch
Aug 17, 2008 05:20 AM
jordan_civic
Jun 24, 2008 03:39 PM
Chief Brody
Honda Motorcycles
22
Jul 30, 2004 04:00 PM
LostGsr
Apr 7, 2004 01:51 AM
