Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Code P2647 A Rocker Arm Actuator System Stuck on Bank 1
Old Jul 16, 2022 | 03:37 PM
danielocallahan's Avatar
Default Code P2647 A Rocker Arm Actuator System Stuck on Bank 1
Hey guys!
I am getting a check engine light error "p2647" which is stating "A Arm Rocker Actuator System Stuck on Bank 1"
I have tried to replace the Oil Pressure Switch that is located above the oil filter (I have a D17 engine that is not equipped with a VTEC Solenoid)
I am experiencing symptoms like others are for a bad VTEC Solenoid. Car can cruise up to 40 MPH but if I try to press on the gas I lose all power in the engine and the car basically goes limp.
I have also recently changed the oil with 5w-20. Oil is topped off and clean.
And ideas on what else I can do? I am thinking about ordering an OEM oil pressure switch versus the one I got from Autozone to see if that makes any difference.
E38Mk1
Honda CR-V & Element
Oct 25, 2021 12:36 PM
tyvtec23
Mar 7, 2021 05:05 PM
kds24
May 3, 2018 01:06 AM
pvuchetich
36
Nov 11, 2017 08:55 PM
s1ngle
May 6, 2005 06:50 PM
