Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
2017 Pilot Smart Sensing Lock Cylinder removal
Old Jul 13, 2022 | 04:08 PM
Dyingdevil87's Avatar
Default 2017 Pilot Smart Sensing Lock Cylinder removal
I'd like to have a lock cylinder from the driver door handle recoded by a locksmith. From what I've seen I think I can remove the lock cylinder my simply undoing the 10mm bolt on the side of the door, and do not have to open the door panel. Can anyone confirm?
Old Jul 13, 2022 | 04:19 PM
Ryanthegreat1's Avatar
Default Re: 2017 Pilot Smart Sensing Lock Cylinder removal
I highly doubt that. I have done door cylinders on a couple of different Hondas and the lock cylinder is literally the first step to assembling the door.
It very well could be a single bolt holding the door handle in place but to access that bolt you will need to strip the door to nothing.
Old Jul 13, 2022 | 04:58 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
If you're just removing the driver's front door cylinder (# 23 and 25 in the 2nd parts diagram), then yes.
A plug cap (#28 in the 1st parts diagram) is removed from the side of the door, then the bolt is removed to take out the door cylinder. Anything else like the door handle, etc.; requires the door panel removal.
Old Jul 13, 2022 | 05:51 PM
Thank you! That's what I thought but couldn't get confirmation.
CreatorLakers
Honda Civic (2001 - 2005)
May 20, 2017 08:12 PM
tmoor
Dec 10, 2011 05:59 AM
JoePSI
Mar 10, 2006 06:14 AM
CaptivaBlue
Mar 12, 2005 04:16 PM
