Need a bit of help.. Someone tried stealing my civic.
Old Jul 13, 2022 | 02:11 AM
EmersonsCivic's Avatar
Default Need a bit of help.. Someone tried stealing my civic.
Hi all,
Last night someone tried to steal my Civic 89' hatchback with some scissors. Luckily they haven't been able to take the car but they've mangled up both the door locks and the ignition cylinder, the steering lock also doesn't seem to work anymore.
I'm now trying to replace the ignition cylinder or at the least pull it out to get a part number.. I have unscrewed the three screws for the steering column cover and have managed to use my key to get to the number one position on the ignition but the hole you need to push in doesn't seem to work no matter how much I have tried to wiggle it.
Any suggestions on what's wrong? Will I need to replace the whole ignition switch?
Cheers,
Em
Old Jul 14, 2022 | 05:56 AM
Marcos Barrios's Avatar
Default Re: Need a bit of help.. Someone tried stealing my civic.
you shouldnt have to replace the ignition switch
but the key cylinder yes
if you can find a used key cylinder
ill run you threw the process of making it work with your original key
Old Jul 17, 2022 | 10:36 PM
Appreciate the response, I have found parts from a local distributor but I'm just having trouble actually getting the cylinder out. The button to release it won't depress. Any advice?
Old Jul 22, 2022 | 12:40 AM
Hey Marcos,
I have managed to get out the cylinder by removing the cover from the cylinder and then trying to push down the pin again, worked straight away!
How do I get access to the wafers of the cylinder so that I can make sure my keys work with the new cylinder?
Thanks,
Em
Petite1234
Oct 28, 2014 04:28 PM
DylannD
Aug 4, 2014 01:07 AM
Studiox1
Feb 5, 2007 11:17 PM
IDGAF2885
13
Apr 21, 2005 07:18 PM
VTECdTypS
23
Jan 20, 2005 02:25 PM
