eBay oil pan
Old Jul 12, 2022 | 04:15 AM
710oZcar's Avatar
Default eBay oil pan
Anyone ever used this ? Just wondering if it will bring my oil temps up? Or help n bring it lower ? Bought few years ago .
Old Jul 12, 2022 | 04:39 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: eBay oil pan
you meant....AMAZON oil pan. What's wrong with using a normal oil pan??
Old Jul 12, 2022 | 05:42 PM
Ryanthegreat1's Avatar
Slammed stance boi, pan got crushed and OEM is too spensive.
Paraphrasing of course.
Old Jul 13, 2022 | 09:08 AM
710oZcar's Avatar
true i feel u im low but havent fcked up my oem pan yet. u think the baffled pan is better ?
Old Jul 13, 2022 | 09:09 AM
710oZcar's Avatar
yee my bad . nothing wrong with the oem one i have just wondering if this is lil better? also since it has the baffle it might be a lil better.? just trying to see if anyone uses it. its basically a moroso oil pan without the logo.
Old Jul 13, 2022 | 01:37 PM
The factory pan has baffles. I wouldn't waste my money if the factory pan is in serviceable condition.
Old Jul 13, 2022 | 10:10 PM
710oZcar's Avatar
the oem is hallow isnt it ? like i seen them before and they have no baffle like the moroso one. i could be wrong but from wat i seen, seems like its got some type of cover to make sure it gets oil.
Old Aug 1, 2022 | 09:47 AM
99pearlude's Avatar
I bought a similar pan from ebay because it already had the welded bungs for my turbo build. I wish I hadn't bought it, none of the holes on the pan lined up with the block when installing it. I had to re-drill the newly bought oil pan to make the studs line up, and even then it was tight.
Last edited by tech8; Aug 1, 2022 at 10:47 AM. Reason: This is not the marketplace.
Old Aug 1, 2022 | 11:57 AM
aw614's Avatar
10 Year Member
Loved
Though the baffles on that pan the OP posted looks a lot closer to the PW JDM weld in baffles than the regular b series oil pan.
Old Aug 1, 2022 | 06:06 PM
NVturbo's Avatar
O.G. triple O.G.
I'm currently running a "OEM" style oil pan on my Del Sol and didn't have any issues with it. Sometimes, it is a hit or miss when it comes to precise fitment with aftermarket parts.
Old Aug 2, 2022 | 06:58 AM
Chance EG's Avatar
The OEM pan does not have baffles around the pickup.
I have had good experience buying oil pans from Remtune, he pre-welds baffles and AN bungs (if asked) onto the pans he sends out. No fitment issues.
Old Aug 2, 2022 | 12:29 PM
Maxcapacity's Avatar
To the ops question.. the oil temp is not going to change using that pan. It's only going to help with the sloshing keeping oil at the pickup if your tracking your car doing constant hard turns and braking. If you want to lower the temperature just get a external oil cooler like a small B&M one though you shouldn't really need one. You could also heat wrap your exhaust manifold that travels under the pan to help the temp lower a tad. I like using DEI wrap.
Old Aug 18, 2022 | 01:43 PM
710oZcar's Avatar
NICE NICE yea i ended up getting a oem pan w baffle welded in it, but most deff might wrap the exhaust.
Old Aug 18, 2022 | 01:44 PM
710oZcar's Avatar
thats wat i just bought tbh ahaahah. so liking it? ima put it on next week wen i have some time.
90si-rex
12
Dec 7, 2014 03:05 PM
longskate87
Transmission & Drivetrain
Jun 29, 2009 07:45 PM
djnikko
Mar 6, 2008 01:25 PM
93c1sol
May 20, 2006 08:58 PM
FONK
Mar 15, 2006 06:07 AM
