2004 Honda Accord EX 2.4 PROBLEMS AND SUGGESTIONS
Hello.
I have a 2004 Honda Accord 2.4 EX Sedan and has 230k miles. I have owned it since 2010 and loved it. I have 3 problems right now and want to resolve them. Problem 1 is poor acceleration. Sometimes not all the time it really needs gas to go pass 2k-2.5k RPMS. This is getting annoying as I don’t really like pushing the car to much, but when that happens it requires me to give it extra throttle because it really doesn’t want to go pass 2k RPMs. Problem 2 is when I’m at idle in D parked or at a stop light when I press the brake pedal there is a vibration that happens for a second will go away and then happen for another second. Problem 3 is braking from high speed. When pressed really hard at 60 you’ll feel vibration and see it from the steering wheel. I replaced the old rotors and pads and both CV axles and control arms. All in the front. Also cleaned the VTEC solenoid screen and did a fluid flush. Everything to fix these 3 problems. Let me know your suggestions down below.
Thank you
Thank you
pstevens90
Nov 16, 2014 04:32 PM
salvi
Mar 22, 2006 10:09 PM
