Valve cover leak.. what am I missing?
Old Jul 5, 2022 | 09:00 PM
Hammerschnitzel's Avatar
Default Valve cover leak.. what am I missing?
1991 Accord F22.. Replaced all the gaskets/seals/grommets, looks like the cover leaks in the upper right corner. Installed a new gasket set and same issue but not as bad of a leak- still about two tablespoons when parked. Small drip while running. Online manual has nothing other then "replace when damaged or deteriorated". Just lost on what to try next.. tia
Old Jul 6, 2022 | 07:05 AM
nicolaselias's Avatar
Loved
Community Favorite
Default Re: Valve cover leak.. what am I missing?
Did you properly clean the area before putting the new gasket? You can also try some RTV silicone on the corner since that for whatever reason always tends to be the spot to leak
Old Jul 6, 2022 | 07:54 PM
Thanks for the response- I cleaned it pretty well but I guess I can try again with some carb cleaner/rag. So I take it l that this tends to be a common issue?
Old Jul 7, 2022 | 05:44 AM
Loved
Community Favorite
Yep, that corner is always known for leaking.
I would suggest using a little RTV silicone (grey or black is fine) to help seal the corners in particular.
Can re-use the gasket once it hasn't been crushed or pinched or anything.
What condition is your PCV valve btw? Did you check it (can blow through it to check) . Or can change it anyway since it is super cheap.
Old Jul 9, 2022 | 06:35 AM
Cleaned up the seating surface, and used a little Hondabond. Allowed to cure- pvc valve is good. Sprinkled baby powder on that area and ran the engine. Valve cover isn't leaking but oil is still pooling on that ledge so my guess is that's the timing cover? No idea how that would all of a sudden start..
plugger
Jan 3, 2010 11:01 AM
dc5tegk20
Aug 24, 2006 12:40 AM
pos_cd5
Jun 17, 2006 05:21 AM
xd69
Oct 16, 2004 11:22 PM
mulpha
Jan 14, 2004 04:01 AM
